Old 02-14-2013, 02:46 PM
  #29081
GreenJK07's Avatar
Originally Posted by Christarp
Put on my rubicon express 3.5" superflex lift! Turned out great, instructions were dildos but luckily it was mostly common sense stuff (that is after reading this forum for months).
End result:
Really great kit for the price, came with everything I needed. Front adjustable track bar, rear track bar bracket, front sway bar disconnects, rear sway bar links, steel brake lines all around, springs, bump stops, all 8 control arms (only uppers are adjustable though, but the lowers are set to where you would adjust them anyway), and completed the kit with bilstein 5100s.
Used to run the same lift. Punished it and beat on it for years. Only thing I can complain about was the shocks. THEY SUCK!!! I had the monotube ones too. After swapping to a rock krawler lift, I found that both rear rubicon express shocks were blown. Could tell the difference between working and not.....
Old 02-14-2013, 02:47 PM
  #29082
GreenJK07's Avatar
Originally Posted by 007 JKX
Found a spot to store 2 quarts of oil and or coolant<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=422255"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=422256"/>
Sent from my iPad using Tapatalk
Wow! This is great! You should also post under low cost/free mods!!!!
Old 02-14-2013, 02:53 PM
  #29083
007 JKX's Avatar
It is in there too
Old 02-14-2013, 03:04 PM
  #29084
GoDucks77's Avatar
Default Installed 4" Evo Plush Coils
Slowly dismantling my FabTech 3" lift. Installed Upper Rear Control Arms and Evo Plush 4" Coils. First road test complete (Noticeable Ride Difference).
Before with Fabtech 3" lift
After 4" Evo Plush Coil Springs
Old 02-14-2013, 03:28 PM
  #29085
sgtkersh's Avatar
New shoes installed. MB TKO 15" with 33/12.5/15 Duratracs. Feels totally different. Oh, and installed a Cobra 75 while waiting on UPS to deliver the tires.
Old 02-14-2013, 05:43 PM
  #29086
4WheelingAstronomer's Avatar
Originally Posted by dhpinned
Tubes are on....
Sort of done Im going to mess with driver side the original damage made it look off with the recess of it and tilt.
Its pushed in and even with banging it out the panel still lays in a smidge, as well as I need to finish grind. Then I'll do the primer and paint to clean it up...probably after JV Saturday...don't want to do it twice
Oh damn that is SEXY
Old 02-14-2013, 05:44 PM
  #29087
Clever!! How much was that mod, just typing something because "clever!!" is too short a message
Old 02-14-2013, 06:15 PM
  #29088
baeteamjk's Avatar
Installed a 5W/15W PA speaker and I can't hear a thing! Is 5W just too weak? It only connects to the CB with a standard jack and no external power wires. Thinking its just too weak.
Old 02-15-2013, 09:38 AM
  #29089
slingshot289's Avatar
Finally done with lift
ID:	422497   Click image for larger version
ID:	422498   Click image for larger version
ID:	422502   Click image for larger version
Old 02-15-2013, 09:44 AM
  #29090
palehorse's Avatar
Looks great! What lift?
