Put on my rubicon express 3.5" superflex lift! Turned out great, instructions were dildos but luckily it was mostly common sense stuff (that is after reading this forum for months).
End result:
Really great kit for the price, came with everything I needed. Front adjustable track bar, rear track bar bracket, front sway bar disconnects, rear sway bar links, steel brake lines all around, springs, bump stops, all 8 control arms (only uppers are adjustable though, but the lowers are set to where you would adjust them anyway), and completed the kit with bilstein 5100s.
End result:
Wow! This is great! You should also post under low cost/free mods!!!!
Originally Posted by dhpinned
Tubes are on....
Sort of done Im going to mess with driver side the original damage made it look off with the recess of it and tilt.
Its pushed in and even with banging it out the panel still lays in a smidge, as well as I need to finish grind. Then I'll do the primer and paint to clean it up...probably after JV Saturday...don't want to do it twice
Originally Posted by 007 JKX
Found a spot to store 2 quarts of oil and or coolant<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=422255"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=422256"/>
Sent from my iPad using Tapatalk
Installed a 5W/15W PA speaker and I can't hear a thing! Is 5W just too weak? It only connects to the CB with a standard jack and no external power wires. Thinking its just too weak.
