Old 10-05-2008, 06:55 PM
  #2781
vwJarhead's Avatar
Put the hard top back on today
On a lighter note my sound system sounds better
Old 10-05-2008, 07:11 PM
  #2782
hntndawg's Avatar
Added a Rough Country 2.5" BB. Very happy with how the look turned out. Yet to see how the flex is changed
Old 10-05-2008, 10:02 PM
  #2783
Superman1023's Avatar
Default BDS Lift " 2door
ok first off pictures coming soon sry! I finished my lift and bumpers. I have a question for you all I wrote more in depth under the thread benefits of adj. control arms. my bds custom kit was ordered with rear up/low adjustables but the front is all stock. the adjustable front would NOT go on so Im running a stock fixed front all adj. rear? what should I do and is it necessary to relace your stock fixed for aftermarket fixed or just a waste of $? thanks
Old 10-06-2008, 07:29 AM
  #2784
Dwikto's Avatar
how big a lift? generally as i understand check with WOL 3" and under stock control ok 4" and up adjustable recommended.
Old 10-06-2008, 07:42 AM
  #2785
jtwjk's Avatar
i spent 3 hours getting pine sap off again
Old 10-06-2008, 08:59 AM
  #2786
Leedsfighting17's Avatar
Originally Posted by Dwikto
YELLOW GRILL MOD
FREEDOM TOP INSULATION FOR ABOUT $10.00
I like the insulation idea. may have to try this as my top should show up tomorrow.
Old 10-06-2008, 10:03 AM
  #2787
scotlandjk's Avatar
Attachment 13793
hey just wondering how that wireless switch is wired up, do you have to supply each relay with a 12v. also have you just run two wires straight from the battery to the fuse box and then into the relays ?
im not sure how i should wire it, can i just take one pair of wires from the battery to a fuse box which has multiple fuses and then to the relays? i have a 12ch wireless relay switch
Old 10-06-2008, 11:59 AM
  #2788
Seir's Avatar
Default New tires and wheels...
Bought another set of 17" Jeep wheels, a set of TPMS and found a set of 5 lightly used Rubicon tires (thanks PastorSteve for pointing me to the Craigslist posting). Had them built on Saturday, put them on and stored my stock wheels/tires (will use them for summer highway driving). Then took off for a short fall color trip with my 4yr old. The tires worked great and I could feel a definite improvement even on the simple trail we took.
Old 10-06-2008, 01:05 PM
  #2789
jeepin08's Avatar
tinted my turn signal lights with flat black spray paint. No night shots as of yet but still work very well
Old 10-06-2008, 01:16 PM
  #2790
redWRANGLER's Avatar
I like. what did you use?
