#2783
BDS Lift " 2door
ok first off pictures coming soon sry! I finished my lift and bumpers. I have a question for you all I wrote more in depth under the thread benefits of adj. control arms. my bds custom kit was ordered with rear up/low adjustables but the front is all stock. the adjustable front would NOT go on so Im running a stock fixed front all adj. rear? what should I do and is it necessary to relace your stock fixed for aftermarket fixed or just a waste of $? thanks
#2784
#2786
#2787
1 Post
Attachment 13793
hey just wondering how that wireless switch is wired up, do you have to supply each relay with a 12v. also have you just run two wires straight from the battery to the fuse box and then into the relays ?
im not sure how i should wire it, can i just take one pair of wires from the battery to a fuse box which has multiple fuses and then to the relays? i have a 12ch wireless relay switch
#2788
New tires and wheels...
Bought another set of 17" Jeep wheels, a set of TPMS and found a set of 5 lightly used Rubicon tires (thanks PastorSteve for pointing me to the Craigslist posting). Had them built on Saturday, put them on and stored my stock wheels/tires (will use them for summer highway driving). Then took off for a short fall color trip with my 4yr old. The tires worked great and I could feel a definite improvement even on the simple trail we took.
#2789
tinted my turn signal lights with flat black spray paint. No night shots as of yet but still work very well
#2790
