Yea it worked out pretty well. It isn't quite as bright as the stock one but it is right in the line-of-site of anyone behind so it still works great. I flush cut the factory bracket off and sanded it smooth before retouching the paint. This is kinda important because this area is more visible once this real estate is opened. I used a 3 1/2" wide by 12" long piece of 10g(1/8") aluminium. With my rim the bend was put at 4 5/8" from the top. I cut the bottom off at 3". Drilled thru holes in the new mount and drilled and tapped three M5 holes in the carrier. The light called for a 2 5/8" hole, but I used a 2 1/2" hole saw and it worked perfectly! Tech-tip... Warm the aluminium before you bend it. The piece I got had a high silicate level, (as most cheap stuff does), and I was worried it would crack. Steel would be no problem but I didn't have any.
I told the guys a work this story and 2 of them said they get the same deal too.
Try using this story, maybe it will still work for you.
My JK gave birth to a beautiful baby Hurricane this morning!
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=400199"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=400200"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=400201"/>
Course I had to have fun with it before I give it away as a Christmas gift
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=400202"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=400203"/>
