#2701
Where did you extend them to? I'm really needing to do the same now that I have my snorkel on... Don't want a false sense of security, though I'll prolly still check fluids if I get real deep for very long.
#2703
#2704
Monday night: Brought home new '08 Rubicon Unlimited
Tuesday night: I installed the black Mopar fuel door.
Tonight? Pick up perforated stainless steel for grill mod
#2706
Installed ARB differential
Yep I installed the front cover (RED) changed the lube oil. a bit of advice don't go beyond the 14K miles to change the fluid (diff) I changed the fluid on the rear and it was bad looking (this is normal per Eddie) I even used brake cleaner to clean it out. I looked at the new Differential fluid again, looked ready to change even after using Mobile ! full Syn less than 400 miles. I'll check it more often now that I have a dip stick with a magnetic end. of course unless you would like to replace the gears to 513, and put 35 or 37 tires on the Jeep
