Originally Posted by jeep_n_co
I disagree. I have a bone-stock lighting setup (2007), and I get flashed as if I had my high beams on by oncoming traffic all the time. With low beams on and without fogs, I can't see a damn thing in front of my jeep. If I turn my fogs on, I can see immediately in front of jeep, but oncoming traffic would be blinded (I get flashed twice as much). And yes, I have re-aimed my headlights, they just have a really poor beam pattern.
This is the worst factory lighting I have ever seen in a vehicle. I will be looking into headlight upgrades asap.
Do you have a lift on your jeep? I have 3/4" coil spacers all around, so I'm a little (yes I said little) bit higher but still have the rake effect (front lower then the back of about 1") so in my case with or without fog on, I don't blind people. I agree with you that the stock head lights are crap... I'm curious about the Vision X fog replacement kit (picture).....nobody make comments about them?!?!?
Received my artec front axle truss, Evo gussets, Evo front control arm skids, waiting till I get my teraflex long control arms and rear truss and 37s to do the install tho
No lift, no "rake kit" either. Bone stock suspension. I am running 35" tires, but I had this problem with stock sized tires as well. I actually like my stock fogs, apparently the 2007 had better fogs than any other year, so I haven't looked into fog replacements at all.
Originally Posted by k0260
finally swapped my front Bilstein 5100's for Fox 2.0 remote res shocks. Added a couple more tools to tailgate.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=389737"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=389738"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=389739"/>
added a few things:
EVO 1/4 pounder stinger
Synthetic winch line
Factor 55 thymbol
Synergy steering stabilizer
1 ton tie rod
Currie antirock front swaybar
Antirock rear swaybar
Factor 55 thymbol
1 ton tie rod
they're awesome. I was happy with the Bilstein 5100's, but I wanted more travel with much more sensitive dampening. These feel a ton smoother on harder rougher hits, especially at speed. To get max travel, I went with the 4"-6" length for my 3" lift.
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
