Yesterday I added a receiver hitch with and wiring harness, and today the bestop narrow bumper and SB X20 winch (just finished about 20 minutes ago)
Before
![](http://i1003.photobucket.com/albums/af157/kbperry810/Jeep%20JK/JeepBefore.jpg)
After
Before
After
![](http://i1003.photobucket.com/albums/af157/kbperry810/Jeep%20JK/JeepAfter.jpg)
Installed Mopar Fuel Door... Had to get the chrome screws out the picture, will be touching it a lil more once I feel like it. Sits flush against the body. Clean install..
![](http://i47.tinypic.com/usaax.jpg)
![](http://i46.tinypic.com/14kv3au.jpg)
Slowly but surely I'll get to where I want to be. Makes the journey last longer ha.. But, Does it ever stop?
![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
Originally Posted by Makeitwork
Slowly but surely I'll get to where I want to be. Makes the journey last longer ha.. But, Does it ever stop? ![Thinking](https://www.jk-forum.com/forums/images/smilies/thinking.gif)
IF, it ever does come to a stop, then it's time to get another new, stock Jeep, and start the journey all over again . =:-o
Originally Posted by Ooothatguy
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=371126"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=371127"/>
Originally Posted by scratchkenny
Is there a write up for this??
Trucklite LED's, part # 33050Y. First I sprayed a few light coats of VHT Night shades on the lights. Then I measured the fender and centered the first light which came out about 6.5" from the inside of the fender (closest to body) out. I measured an inch up from the bottom of fender and drilled out the center point using a step bit to 3/4". Then I centered the other two front lights between that all at 1" from the bottom. The side light, I honestly eyeballed where they look the best to me. Once all the holes were drilled, I installed the grommets that come with the lights, the lights and the soldered them all in line and tied them into the original side marker light wiring. Pretty simple, took about 2 hours. I think I'm going to do the blinker mod now so they blink with the turn signals. Hope this helps! If you do it, be sure and post some pix!
