Originally Posted by fadeout
Why do you still have the old TieRod they will swap that design out for you with the stronger bar and better designed jam nuts instead of the clamps. Its covered under their warranty for it. Unlike the drag link which I wound up paying another $200 bucks to fix. Give them a call.
I've lost all hope in currie after dealing with these issues more than once. If I did it again I WOULD NOT buy this currie setup.
Did u see the whole setup is now over 1000$!
And those big foam disks I can't see lasting to long rubbing on the knuckle as steering is cycled.
Originally Posted by Xman4602
What brands should I be comparing? Should I replace factory tie rod and drag link while i'm at it?
Rock krawler makes a great setup! after all the issues I've had with my currie stuff, I would not recommend them.
Quick questions, if someone could help me it would be great:
1) when you put 2 driving lights (Hella 700FF 55 watts / 7.5" diameter) on the front bumper, to have the best lightning is there a specific space needed between them?
2) does someone have a picture of a deep water blue wrangler with a roof light bar??
Thanks
Thanks
Yea I know. Spoke to David before getting anything. He said I pay 189$ plus shipping and they send me a new bar.. Get a 189$ refund once currie get it back.. My issue was the joints were bad, and I would've had to buy a new tie rod clamp for my ram, and I still needed new ends, and those expensive washers to prevent rotation. Couldn't see wasting all that money when all I need was the end cartridges and the 17$ washers, which are a piece.
Originally Posted by 10frank9
Ripped off my crappy OEM plastic rear bumper. Can't believe how light that thing was. What a joke. I cleaned up the frame rails.... Looks great IMHO.
I found these, I don't know if this helps.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=347189"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=347190"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=347191"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=347192"/>
Thanks a lot.
Any idea about my first question?
