Old 06-30-2012, 11:30 AM
  #23171
MiJKguy's Avatar
Default What was done this whole month!
Name:	new paint.jpg
ID:	335519Click image for larger version
Name:	jk decal.jpg
ID:	335520Click image for larger version
Name:	new hinges.jpg
ID:	335521Click image for larger version
ID:	335522Click image for larger version
ID:	335523grill insert , bedline grill & door hinges duplicolor paint on interior
Old 06-30-2012, 11:32 AM
  #23172
bob-o's Avatar
Well today I put on spidertrax wheel spacers and a sway bar disconnect motor skid plate from purejeep.
Old 06-30-2012, 12:00 PM
  #23173
g0rmac's Avatar
Washed it ! and drove to Peggys Cove.
Old 06-30-2012, 12:11 PM
  #23174
baeteamjk's Avatar
Replaced the crappy Made in Mexico stock speakers in my 2007 X with some Infinity speakers from a 2012. Huge difference! The weight alone indicates a much better quality product.
Old 06-30-2012, 12:18 PM
  #23175
ThePalmBeachYeti's Avatar
The 2012 speakers are nice, the sub too.
Old 06-30-2012, 01:25 PM
  #23176
jeepasaur's Avatar
Originally Posted by twalk482
Would like some details on the grill/bedliner mod ... I was thinking about doing it too.
The grille is plastic so preparation is key...i used duplicator adhesion promoter and duplicator bed armor...sand the surface really well and make it really rough I used 180 grit sand paper and skateboard grip tape...clean the surface really well I used 90% rubbing alcohol which helps remove any remaining clear coat and cuts the paint a little as well giving u a good surface to adhere to...then make sure the piece is completely dry and PATIENTLY apply between 5 and 8 thin coats allowing the Bedliner to set just a little in between that way u won't get the runs haha...then let cure overnight and reinstall....you can follow those steps for pretty much anything plastic that you want to bedline....let us know how it goes!!
Old 06-30-2012, 03:23 PM
  #23177
Sabotage70's Avatar
Originally Posted by 4WheelingAstronomer
Did you make this yourself? If so nicely done. A bunch of us were looking for something like this
Yes. I have access to a sheet metal and a break. The CB mount started as a U shaped piece of i think 22ga but it may be 24ga metal and I trim it down to what I needed.
The antenna was an 18ga piece.
Speaker arrived today so I put that in.
Old 06-30-2012, 03:37 PM
  #23178
rlew0083's Avatar
Washed her up for trip to the beach tomorrow. Thank goodness it is cooler there, 109 in AL today.
Old 06-30-2012, 04:16 PM
  #23179
treid's Avatar
installed cobra 19 dx iv , hope its a better radio than the reviews I've read recently
Old 06-30-2012, 04:51 PM
  #23180
KCCO JK's Avatar
Installed my new RR XHD w/ Stinger and Recon 10,500 lb winch.
Tomorrow, I'm going to be installing(or at least attempting to install) a Die Hard Platinum P1 Group 34. The dimensions seem to suggest that it will fit in my '12(which I got from Project-JK's Group 35 install). The difference between the two batteries is 15% more CCA(850 vs 740), and 35% more reserve capacity(135 vs 100)... So it was too tempting to resist the desire to at least TRY considering they cost the exact same. I can try to make a write-up for it if anyone would be interested(which also depends on it working haha!)
