Old 04-12-2012, 09:45 AM
  #20841
08GreenRubi's Avatar
Originally Posted by Mid Life Crisis
Rugged ridge hood latches and chrome antenna base. What you guys think?
Sorry, I just can't get on board with the chrome I can appreciate that it is not stock anymore though
Old 04-12-2012, 09:49 AM
  #20842
wesplains's Avatar
Had to replace front diff gasket. 2008 at 30000 miles.
No fun stuff done/added.
Old 04-12-2012, 10:44 AM
  #20843
DeucesALLin's Avatar
Default Battled passenger side seatbelt bolt...
After 3 dudes, PB Blaster, and an IMPACT GUN were all used IN VAIN to remove the bottom seatbelt bolt I discovered an INSTANT fix :
1) Remove seat
2) Use cutting wheel to remove seatbelt bracket by cutting a notch out and simply pull retractor mechanisim off of the anchor bolt
3) Use said cutting wheel to make TWO cuts on the bolt, removing just enough material to make a symetrcal plane
4) Use channel locks to remove the bolt
5) Replace seatbelt
6) Tighten it back with the Torx bit
7) Replace seat
Old 04-12-2012, 11:13 AM
  #20844
GreenJK07's Avatar
1) Remove seat
5) Replace seatbelt
7) Replace seat
I know your pain and frustration. I battled my rear seat belts in my 2 door when I removed them. My impact had a tough time but after applying some heat, they came right out.
Old 04-12-2012, 12:23 PM
  #20845
PaddyMurphy's Avatar
Added my first west coast pinstripes over the Easter Weekend. I cringed, but the wife, jeep, and son loved it!!
Old 04-12-2012, 01:08 PM
  #20846
Jeepmed's Avatar
IONS AND 33" Nittos
Old 04-12-2012, 01:40 PM
  #20847
Xman4602's Avatar
Added D-ring shackles and daystar isolators.
Old 04-12-2012, 03:36 PM
  #20848
Alflinn's Avatar
Trektop nx and aev bumpers.
ID:	303171   Click image for larger version
Old 04-12-2012, 03:45 PM
  #20849
HELLBENDER-JK's Avatar
What tail light guards are those?
Old 04-12-2012, 05:04 PM
  #20850
Stephane87's Avatar
Are those rear corner guard from Buschwacker? Do you like them? Do they change color under the sun or same as the original flares?
Thanks
