Battled passenger side seatbelt bolt...
After 3 dudes, PB Blaster, and an IMPACT GUN were all used IN VAIN to remove the bottom seatbelt bolt I discovered an INSTANT fix :
1) Remove seat
2) Use cutting wheel to remove seatbelt bracket by cutting a notch out and simply pull retractor mechanisim off of the anchor bolt
3) Use said cutting wheel to make TWO cuts on the bolt, removing just enough material to make a symetrcal plane
4) Use channel locks to remove the bolt
5) Replace seatbelt
6) Tighten it back with the Torx bit
7) Replace seat
1) Remove seat
5) Replace seatbelt
7) Replace seat
1) Remove seat
5) Replace seatbelt
7) Replace seat
1) Remove seat
5) Replace seatbelt
7) Replace seat
