Good, busy THE SUN IS OUT Jeep weekend. Projects time:
Oil change
Checked control arms torque
Drilled speed holes in the rack upper gussets
Bedlined the rack, resprayed corner armor and rear body quarter panels; all but the windshield bar and upper rails are done. Ran out of go go and bedliner.
Oil change
There's a diy tool i've seen people use. Inside the housing use a threaded rod with nuts and large washers on both ends. With one end fixed and press against one of the seals keep threading the nut on the other side to press the washer against other seal. Keep threading until both sides are pressed into place
Sent from my ADR6400L using Tapatalk
