Originally Posted by DJCFHB
You'll be fine with the drilling, that part easy. I just had to trim this tab a little with a reciprocating saw so all the bolts would line back up. Little touch up paint and i was good to go.<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=284843"/>
Another question. Did you mount or test fit before you had it powder coated or just did it all after?
Installed another RAM mount on my e-dock to hold a UMPC running Windows 7.
Looking for a good topo map for off-road navigation. Can also manage and play audio files on my Jeep's sound system.
Viliv S5 UMPC
Then, installed Dominion's bracket for the Viair compressor and started checking best place for the tank.
The 2.5 gallon tank does not fit well in the engine compartment. Therefore, contemplating either under the Jeep or on the Or-Fab tire-can carrier.
I'll also likely place the air intake port in the cabin.
Viliv S5 UMPC
Did some wiring!
This the fuse panel I added in the engine bay to hold my AUX light fuses I made and powdercoated the bracket myself looks about as factory as you can get. The Black wire you see there is just laying there.
