Old 11-20-2011, 07:28 AM
  #17331
Jeepnut67's Avatar
Post Installed factory front tow hooks...
after cutting out the holes on the stock plastic cover.
Old 11-20-2011, 09:00 AM
  #17332
maine07jk's Avatar
Installed a new Slave Cylinder and my new Tuffy under seat security box today!!!!!!
Old 11-20-2011, 09:27 AM
  #17333
J-VET's Avatar
Tinted the Front windows and Clay barred then waxed.
Old 11-20-2011, 09:34 AM
  #17334
Cdyspeed's Avatar
Originally Posted by ludski
swapped out my 1.5" leveling kit. and put on skyjacker 3.5" coils. still rollin on body lift and 37s.
now has 3.5" coil lift, 1.25" body lift and 37s. almost making the 37s look small.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=239321"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=239322"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=239323"/>
Heres size distance with a jeep with:
2.5" teraflex coil lift, 1" body lift and 37s.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=239324"/>
That looks a lot better how does it ride with that lift?
Old 11-20-2011, 09:41 AM
  #17335
JackDANJK22's Avatar
I got one !
Old 11-20-2011, 09:45 AM
  #17336
JK-Rubi's Avatar
Is that 2DR a member's JK? I've got the same lift and would like to see more pics of his setup (2.5" teraflex coil lift, 1" body lift and 37s). Thanks.
By the way, your JKU is looking better all the time.
Heres size distance with a jeep with: 2.5" teraflex coil lift, 1" body lift and 37s.
Old 11-20-2011, 09:56 AM
  #17337
JK-Rubi's Avatar
That white one? Its a 4 door. Ha.
Now that I look closer that's evident. Thanks.
Old 11-20-2011, 10:31 AM
  #17338
Bubbacon's Avatar
not bad.
need new links and trackbar brackets (until i can afford new trackbars) cause it tends to have the back end push over a little bit. (new rear trackbar bracket comes in tomorrow)
other than that. stiff. but not bad. i like it.
all temp until i get it replaced with the "official" lift and shocks.
just wanted to get enough lift for T4T run in indiana
When / where is T4T run? I'm in ft Wayne.
Old 11-20-2011, 11:27 AM
  #17339
04sssti's Avatar
My 2dr has rubi springs, 2.5" Teraflex, and a 1.25" body lift with 37's.
ID:	239353   Click image for larger version
ID:	239354   Click image for larger version
Old 11-20-2011, 11:36 AM
  #17340
FlounderKA's Avatar
Did you get the lift kit with the shock extensions?
