Originally Posted by ZMagic97
I removed my subs/tv box. Was taking up WAY too much room. I miss the sound, so I will build a flat space saving box, or put the subs in the side boxes Jeep sells.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=234590"/>
I'm in the process of removing mine as well. I'm removing it because I've had water in my jeep and water gets trapped under the sound deadening. I don't want my tub rusting out because water is stuck beneath it all the time. Also if you don't remove it before you bedline it will look like shit. That's my opinion anyway.
Here you go... about two thirds the diameter of a quarter and half as thick. Stiff center and flexible around the perimeter so it flattens out a little bit as you press it down..
Pop out the stock bumper from the back, clean the debris from the paint using detailing spray and press the caps in from the top. If I went to go back to stock, just push them out from behind.
I am planning a Hi-Lift mounted on the hood and one problem with this is that it blocks the windshield jet. After installing them I realized that this would be a great location to transfer the washer jets to which, I am hoping, will negate the problem with the jack mount location.
Its not seam sealer it's a sound deadening compound.
