Old 11-09-2011, 08:15 AM
  #16981
kungfucracka's Avatar
Originally Posted by ZMagic97
I removed my subs/tv box. Was taking up WAY too much room. I miss the sound, so I will build a flat space saving box, or put the subs in the side boxes Jeep sells.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=234590"/>
That's a good looking box though its a shame its so big.
Old 11-09-2011, 08:20 AM
  #16982
Warpedguy77's Avatar
Originally Posted by Vincent
Just out of curiosity, why not keep the seam sealer there? Does it make a difference say if you're going to Line-X? Thinking of doing this next spring, any advice helpful. I will also do a search on this.
Its not seam sealer it's a sound deadening compound.
I'm in the process of removing mine as well. I'm removing it because I've had water in my jeep and water gets trapped under the sound deadening. I don't want my tub rusting out because water is stuck beneath it all the time. Also if you don't remove it before you bedline it will look like shit. That's my opinion anyway.
Old 11-09-2011, 08:23 AM
  #16983
ZMagic97's Avatar
Yeah, it's HEAVY too. Makes a nice ornamant in the guest bedroom though.
Old 11-09-2011, 08:26 AM
  #16984
fleetwood8890's Avatar
Originally Posted by MikekiM
Here you go... about two thirds the diameter of a quarter and half as thick. Stiff center and flexible around the perimeter so it flattens out a little bit as you press it down..
Pop out the stock bumper from the back, clean the debris from the paint using detailing spray and press the caps in from the top. If I went to go back to stock, just push them out from behind.
I am planning a Hi-Lift mounted on the hood and one problem with this is that it blocks the windshield jet. After installing them I realized that this would be a great location to transfer the washer jets to which, I am hoping, will negate the problem with the jack mount location.
do you have a part number for them?
Old 11-09-2011, 08:29 AM
  #16985
jvandy50's Avatar
i am gonna hafta check under mine to see if water is trapped under there. i was planning on leaving mine in there and just putting my qtec liners back in. and it doesnt look as good, god those sealing things look sloppy, but if its covered up in the front and the back is the only one showing it probably won't bother me as much. either way it'll be better than having carpet in there
Old 11-09-2011, 08:33 AM
  #16986
finnd1's Avatar
that's what he said?
Old 11-09-2011, 08:35 AM
  #16987
I knew as soon as I pushed send that was gonna happen lol.
Old 11-09-2011, 08:51 AM
  #16988
finnd1's Avatar
you can't just give me an opening like that.
Old 11-09-2011, 08:53 AM
  #16989
dgnr8's Avatar
Thats what HE said!
Old 11-09-2011, 08:58 AM
  #16990
Originally Posted by dgnr8
Thats what HE said!
Ziiiiiiinnngggg.
