I've been curious about this for a while.. How heavy is one set of beads? What speed does it take to start them spreading around the tire interior? I would think with a larger size tire it takes more centrifugal force which would need a faster speed.
I guess I am most curious about the low speed effect of this
Originally Posted by 2011COD
I was actually considering getting a specialized license plate "HUMRHNTR" for the ol' Jeep.
Here you go... about two thirds the diameter of a quarter and half as thick. Stiff center and flexible around the perimeter so it flattens out a little bit as you press it down..
Pop out the stock bumper from the back, clean the debris from the paint using detailing spray and press the caps in from the top. If I went to go back to stock, just push them out from behind.
I am planning a Hi-Lift mounted on the hood and one problem with this is that it blocks the windshield jet. After installing them I realized that this would be a great location to transfer the washer jets to which, I am hoping, will negate the problem with the jack mount location.
