Bedlined the front grill and did the plastic grill mesh mod too.
Installed a Rusty's Offroad (Cherry Bomb) Exhaust
http://www.youtube.com/watch?v=9Jv2zV2vqOk
Please post updates on the dynabeads. Just checked out the website. Sounds like a great product. If the beads work as good as the website claims that would be AWESOME!
I had a dodge 1/2 ton 4x4 truck, ran 315 x17 BFG A/T on stock 17x8 rims , no weights just a product called "equal tire balancer) I think 6 oz.s per tire, smoothest tires I ever had on a 4wheeler, the only reason I don't run it now is because "discout tire" does not carry it and I didn't get any of it b4 the tire purchase, I strongly suggest some sort of bead type balancer, it's great stuff
No issue with airing down cause they gave me 4 little valve cores that have a screen on the inner side of them that would not let the "equal tire balancer out" so no issue at all.
Yes you can run this stuff on bead locked (inner or outer) wheels/tires,,, the stuff will move around in the middle of the tire as it rotates due to centrifugal force and it will find the opposite side of the heavy spot of the tire/wheel and stay there. Now about moisture,,, If there is ever a little bit of moisture in a tire due to being sprayed in there from water in air compressor lines when tire heats up the moisture will usually evaporate in a tire,, I know it sounds weird but small amounts of water (not quarts or gallons) that may make its way in the tire will, with enough time and heat from running down the road,, evaporate and be dissapated.
