Old 06-23-2011, 04:34 AM
  #14111
Jknockers's Avatar
Originally Posted by Scooter Scott
Ditto....Mine's been at the shop waiting to get my locker looked at since Sunday
DO ya do much Highway driving?? Have ya thought about sellin that ARB an getting a detroit locker for the back?? They dont hardly fail, I've had plenty
Old 06-23-2011, 04:57 AM
  #14112
MusicBug's Avatar
Mine got some new Bestop half doors for the back to keep the dogs in and my wifes TJ got a new Bestop Trek Top NX!
Old 06-23-2011, 05:53 AM
  #14113
Battlefrog's Avatar
Just vacuumed out the 15 lbs of sand from our beach run 2 weeks ago. It's amazing on much crap makes it's way under the carpet...
Old 06-23-2011, 06:04 AM
  #14114
baeteamjk's Avatar
Bedlined the front grill and did the plastic grill mesh mod too.
Installed a Rusty's Offroad (Cherry Bomb) Exhaust
http://www.youtube.com/watch?v=9Jv2zV2vqOk
Old 06-23-2011, 06:14 AM
  #14115
pderr676's Avatar
Yes. Gonna give them a shot. They balance the tire dynamically while driving, and constantly adjust as needed.. never used them before.
There used , or able to be used in a lot more than u think. Check the site out.
Please post updates on the dynabeads. Just checked out the website. Sounds like a great product. If the beads work as good as the website claims that would be AWESOME!
Old 06-23-2011, 06:19 AM
  #14116
Jknockers's Avatar
I had a dodge 1/2 ton 4x4 truck, ran 315 x17 BFG A/T on stock 17x8 rims , no weights just a product called "equal tire balancer) I think 6 oz.s per tire, smoothest tires I ever had on a 4wheeler, the only reason I don't run it now is because "discout tire" does not carry it and I didn't get any of it b4 the tire purchase, I strongly suggest some sort of bead type balancer, it's great stuff
Old 06-23-2011, 06:41 AM
  #14117
finnd1's Avatar
any issues with airing down when you have those beads in there?
Old 06-23-2011, 07:21 AM
  #14118
Duesy's Avatar
Wondering if those beads would work with inner bead locks??
Old 06-23-2011, 12:01 PM
  #14119
Jknockers's Avatar
No issue with airing down cause they gave me 4 little valve cores that have a screen on the inner side of them that would not let the "equal tire balancer out" so no issue at all.
Yes you can run this stuff on bead locked (inner or outer) wheels/tires,,, the stuff will move around in the middle of the tire as it rotates due to centrifugal force and it will find the opposite side of the heavy spot of the tire/wheel and stay there. Now about moisture,,, If there is ever a little bit of moisture in a tire due to being sprayed in there from water in air compressor lines when tire heats up the moisture will usually evaporate in a tire,, I know it sounds weird but small amounts of water (not quarts or gallons) that may make its way in the tire will, with enough time and heat from running down the road,, evaporate and be dissapated.
Old 06-23-2011, 12:14 PM
  #14120
dirtyharry's Avatar
finally did the chip tuning on my diesel wrangler today
208HP and 470lb-ft torque
burn-out's are very easy now
