Beginning Mods
Simple add-on's while I contemplate bigger projects. "Oh Shit" handle and hook for dry-cleaning!
First time posting pics....if the images above don't work..this is an EPIC FAIL.
Originally Posted by JKRVEE
Got my trailer back from paint, Monday it goes to Line-X, then I can finish it!
hard top removal/superchip
This week I purchased a superchip flashpaq and I'm having some problems with the website. I also removed the hardtop by myself and I dont recommend that. Its pretty heavy and awkward.
Originally Posted by Battlefrog
Did u fabricate this yourself or was it a previous owners build... That is damn cool.......
What did the kit cost you, and where did you purchase it from... Thanx
Trailer 7 point hook up
This week i moded my stock bumper by moveing my trailer plug in to the bumper.
1. 21/8 hole saw to cut thru plastic and some of the metal cross member ( I only cut 1/2 inch in and 1/2 down give or take.
2. Remove plastic bumper remove plastic test fit plug.
3. Hammer the cut peice down . do test fit with bumper and plug.
4. Run connection wire over cross member . Install bumper with out plug. Pull wire thru hole.
5. Conect plug and wire connection. Screw in done.
Why did i do this mod simple it has been ripped off 3 times and i have strated my trailer build .
Originally Posted by jkrvee
i bought it from a guy as basically a rolling box. When it's finished, it will have 200watt music with sirius radio, built in propane system, 10 gallon water tank with an rv style pump, 12v battery, 1000 watt inverter, solar panel, all led lighting inside and out, a removable cooking shelf, and of coarse......coors light on tap!
