Old 03-12-2011, 05:02 PM
  #11921
tcam93's Avatar
Default Mesh Grille Insert from eBay!
I got this from eBay for $46. Apparently someone cut the diamond shaped sheets of aluminum and packaged them with plastic tie thingys and fastners that stick to the inside of the grill after I cleaned it with alcohol. .. for $46, it beats me trying to figure it out how to make it...
Old 03-12-2011, 05:13 PM
  #11922
mark9998's Avatar
Installed some Pilot PL203W fog lights in place of the factory junkers. Got em from Auto Zone for only $39. Holy s*%t these things are bright!!
Factory head lights (low beams):
With only the fog lights on with the Pilot PL203W installed:
This is both the Pilot's and the low beams, not even much of a difference turning the head lights on these fogs are so bright:
Old 03-12-2011, 05:28 PM
  #11923
MotiCross's Avatar
Default 2 more of the grill :)
ID:	136977Click image for larger version
Old 03-12-2011, 05:32 PM
  #11924
MotiCross's Avatar
Thats awesome! how hard was it to put these in the place of the old ones...?
Thanks
Old 03-12-2011, 05:43 PM
  #11925
russellthom's Avatar
Originally Posted by Battlefrog
If you can get your hands on some Rubi coils for the front 18 it will level it out. Right now your coils are either 16/15 or just 16's. I did this last week before my TF 2.5 BB was installed and it leveled out my front end....
Cool thanks for the info. I'll see if I can find some.
Old 03-12-2011, 05:47 PM
  #11926
Battlefrog's Avatar
I'm running 18's on both sides. If you need the actual part number to make your search easier, let me know...
Old 03-12-2011, 05:55 PM
  #11927
mark9998's Avatar
Thanks
Very simple. Here are a couple threads where I came across these and got the info to do this:
https://www.jk-forum.com/forums/show...P-amp-PICTURES
https://www.jk-forum.com/forums/show...ghlight=PL203w
Old 03-12-2011, 06:49 PM
  #11928
DeJK21's Avatar
welp, some d-head pulled my drivers side door handle almost completely off during the night, so i'll be getting that fixed tomorrow
Old 03-13-2011, 04:39 AM
  #11929
Jeeper4Life32's Avatar
[QUOTE="Battlefrog"]
I've heard that the winch needs to be mounted upside down with factory bumper/hidden. Is this correct ?[/QUOTE
That is correct. Mine is mounted upside down as well
Old 03-13-2011, 04:46 AM
  #11930
Originally Posted by mcarr261
What mounting plate did you use and where/how is it mounted behind the plastics?
I used the universal mounting plate from harbour freight. I had to do some minor fab work to it but nothing major. Here are some additional pics so you can see what I did.
ID:	137096   Click image for larger version
ID:	137097   Click image for larger version
ID:	137098   Click image for larger version
ID:	137099   Click image for larger version
ID:	137101   Click image for larger version
ID:	137102   Click image for larger version
ID:	137103   Click image for larger version
ID:	137104   Click image for larger version
