What does this button do?
Thanks everyone for the info does it really work or is it just as easy 2 use the break in 4 low myself. I wish I did have $11,000 for that automatic soft top
Its not a perfect system, but it does work and gives you a bit more freedom to concentrate on your line. Your anti-lock brakes do the same thing, but with just the brakes you control the speed instead of HDC.
I use it occasionally. It will bring the vehicle to a stop if you let it. A little unnerving when you are facing downhill on a really step decline and it stops and you need to gas it to move. Feather touch on the throttle.
