Welding on a Dana 44 axle.
lik you were saying keep the amps low and well......your a welder. everything else is self explanitory.
beat me to it. im mainly stick welding with alittle MIG and TIG. you can def burn through the tube if not careful. im not sure if most ppl understand the potential of a stick welder. MIG is not as hot as stick or TIG.
Also a little pre/post heat would be a good idea since axles have a higher carbon content then the mild steel brackets/gussets people are welding to them...
If your unsure about your welding skills, it's probably worth it to get a professional to weld it for you. Its not only a matter of your safety, but everyone else on the road with you. Not to mention the peace of mind.
If you have any welding questions feel free to PM me...
"the hotter the better" is a very old school way of teaching. But just because it isn't true doesn't mean the opposite is. That statement has some backing. You are much more prone to weld faults welding cold rather than hot, cold lapping and lack of fusion being the main ones. So most welders suggest welding hotter simply because there's less chance of an inexperienced person screwing it up. Rather, if they screw it up they'll know right away(burn through, undercut) as apposed to a cold weld done wrong will often appear fine to an inexperienced welder and could break going down the road.
but i think he understands penetration and if he knows the thickness can formulate how hot he wants to run his bead........not trying to start anything
just trying to back my statement
