Warrior Corners
Warrior Corners
I finally got around to installing my Warrior corners and LED light kit. The corners seem fairly well made, had a few fit issues, but mostly from interference with my Xenon fenders. Not a big issue, just loosened the fenders and everything went right together. The finish(black powdercoat) seems pretty cheap, the slightest touch and it scratched. I plan to tape the corners off and coat them with bedliner after it warms up some.
Overall I am pretty pleased took about 2 hours start to finish, probably could have been quicker but had a little wiring issue(driver's side taillight was getting no power from the Jeep). Tapped into the license plate light and it worked fine.
Here's the pics:
Here's the pics:
Looks interesting but don't most states require either the tail lights be visible from the side (like the stock JK) or side marker lights in the rear? I know here in Commiefornia You would probably get pulled over and issued a fix-it ticket.
