Walmart rock lights 13JKR
Old 03-07-2013, 01:52 AM
  #21
TripleBJK's Avatar
Also, where did you mount the grill light?
Old 03-07-2013, 02:23 AM
  #22
Hskr4x4's Avatar
Originally Posted by ozarkjohn
Yep, hijacking the grill light idea for sure. Are the rock lights mounted in the fender wells or attached to the frame?
Sorry I hijacked this guys thread
I have mine just on frame tucked in. I can adjust by hand all lights if need be, but front will shine in front and back of front tire so I most likely won't install a front light. If I did, it would be for fixing front end if issues on trail not for tire placement.
Here is a write up for where he did his front lights. You can run your wiring however, and it won't be anywhere near write up if u have sPod
Rock Lights - Walmart Platinum Burner Installation Write-Up
Old 03-07-2013, 02:27 AM
  #23
Hskr4x4's Avatar
If wanting to do color lights in motor bay or grille area this will be your best option.. I've used these in multiple show cars and have never had an issue.. Plus this is one of the best customer service companies you will ever deal with (that's if you even do)
Cold Cathodes - Better Glow than Neon
The 6" will light up your whole grille area
Here is the 12" whites I did for floor boards
Quick Reply: Walmart rock lights 13JKR
