Volant snorkel arrived check out the install
that stinks man. but mabey they can just ship u the parts that u need in a seperate box.
and quick ?, does that setup increase performance??
The guy that I bought my Volant CAI from went though the same thing no rubber fittings or clamps when he called I guess they sent him some extra parts that he sent to me with the CAI, If they get stupid on time getting them to you let me know I think I have extra of what you need (that’s if you decide to keep it) I would be raising hell seems they have a problem getting there s*** right As far as the hole in the bottom I don’t think there’s anything to fill it when I called all they said was it was to be left open
Location: Hangin in the sunshine state....staging forum..
are you really saying there is a big open hole in the bottom of the thing? how does the water stay OUT if you get stuck in water that is above that hole or even just driving thru water above it I hope they warranty you engine from hydrolock
yeah theres a hole in the bottom but im sure theres some form of cover has to be doesnt make sense otherwise Im sure they use the same housing snorkel and reg cai except for the lid to keep costs down thats how the tj version was.
The box is the same but if the hole is covered my CAI could fill with water if it would reach the top, there has to be some kind of drain but not a 2.5 inch one. I am not a hard core off roader I will avoid deep water when I can (I have had my days up to the top of the gauges in the swamps here in FL.)
mattymat04 I hope you don't mind the noise My CAI sounds like a wide open 454 with no air cleaner
You are hooked up I will get you the parts if they don't do it quick.
THATS WHAT SHE SAID.......sorry to steal the post but that had to be said
NOW, sucks that you waited so long and the parts were missing. I too would be curious to see completed pics of where and how it passes through the hood and if it makes a true water tight seal.
Good luck
Good luck
Well unless somone beats me to it I will post alot of pics once it goes on. Thanks to (renegadelt1) it will get on one way or another by next weekend. Might not be water tight due to the bottom plug but it will be on there lol and the jeep is so damn loud as is I like it that way.
closed on fridays I emailed em I will call monday. I took off today just so I could do the install. They give a templet for the large hole but theres another 4 bolt holes that you have to drill in the hood . That might be a pita. I would say the hood pushes down on the cai box maybe an in. I cant really tell you cause its in the box in the garage till I can mount the cai box.
