Unlimited on 37x13.50's w/Pictures!
Also, I've got my steering wheel issue fixed but every once in a while my traction control still freaks our and scared the heck out of me. Any reason that is happening?
Is it a kind of low pitched squeak? When installing my lift I made the mistake of not greasing a few of the bushings on the end links and one on the track bar. I ran out of grease so I used lithium spray. About 3 weeks later started squeaking. So I took the track bar and end link bushings and greased them good. Squeak is gone now!!
Unless your steering wheel is aligned perfectly straight this will happen. After the lift my steering wheel was too the left and TC went off a lot. Adjusted it center and it now works as it should.
I didn't grease any of my bushings either. Probably my issue. I just need to take all them back off and grease them properly. And yeah my steering wheel is perfectly centered and when I take turns to the left, it flashes and hits the brakes. Frustrating ha
