Unlimited on 37x13.50's w/Pictures!
Old 02-23-2014, 08:41 PM
Silver_Sahara07's Avatar
Originally Posted by JKBANDIT55
Nice jeep man!! I also run the Zone Offroad 4" suspension! Loving every bit of it! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=533028"/> <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=533029"/>
Also, I've got my steering wheel issue fixed but every once in a while my traction control still freaks our and scared the heck out of me. Any reason that is happening?
Old 02-23-2014, 08:43 PM
JKBANDIT55's Avatar
Originally Posted by Silver_Sahara07
Does your lift squeak at all? Mine does pretty bad when I turn and go over speed bumps. Got to figure out where it's coming from. Drives me nuts ha.
Is it a kind of low pitched squeak? When installing my lift I made the mistake of not greasing a few of the bushings on the end links and one on the track bar. I ran out of grease so I used lithium spray. About 3 weeks later started squeaking. So I took the track bar and end link bushings and greased them good. Squeak is gone now!!
Old 02-23-2014, 08:47 PM
JKBANDIT55's Avatar
Unless your steering wheel is aligned perfectly straight this will happen. After the lift my steering wheel was too the left and TC went off a lot. Adjusted it center and it now works as it should.
Old 02-23-2014, 08:52 PM
fowlinforlife's Avatar
That's a sharp looking setup, those 37 Nitto's look mean.
Old 02-24-2014, 05:08 AM
jaker t5's Avatar
37/13.50 , 4" lift
Old 02-24-2014, 05:26 AM
I didn't grease any of my bushings either. Probably my issue. I just need to take all them back off and grease them properly. And yeah my steering wheel is perfectly centered and when I take turns to the left, it flashes and hits the brakes. Frustrating ha
Quick Reply: Unlimited on 37x13.50's w/Pictures!
