Trimmed Fender thread post ur pics here!
#513
Side marker light. Found a 3/4 amber led trailer weather proof light and drilled a hole and mounted it. Clean and bright!! May smoke the lens to hide it some more.
#516
Yes you can. Just be carefull where you run the wire. You can cause / create a short when running a wire between the body and fender. Mine has pinched and I have to cut a hole to re wire. I bought the set of GenRight LED side markers and mounted between the outer and inner fender with a right angle bracket from Lowe's, and just utilized the existing wire.
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455878"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455879"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455880"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455881"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=455882"/>
~JDub
Sent from this Dang Thing
Sent from my Obama phone while driving my Obama car on the way to get my ObamaCare
#517
After doing my fender trim I decided to start investigating doing LED tail lights. Took the rear light assembly off on the drivers side and saw daylight, lots of it. When you take the inner fender out for the rear fender chop you leave some wide open holes big enough to throw a cat thru. Mud, sand, road salt and snow will get up in there. My passenger side was worse in my opinion cuz they fill it with foam, no way for the crap to come out. What is everyone that has done the fenders doing about this? Especially the passenger side. At least the drivers side you could clean out once in a while. Everyone who has done this mod and has done any wheeling in mud should seriously have a look behind their tail lights. Lets hear what you guys think.
#519
#520
