Trimmed Fender thread post ur pics here!
#471
Can anyone give me a yes or no? I looked through the forums and i didnt find anything about replacing the side markers with an led strip.
#472
~JDub
Sent from this Dang Thing
#473
#474
Yes you can. Just be carefull where you run the wire. You can cause / create a short when running a wire between the body and fender. Mine has pinched and I have to cut a hole to re wire. I bought the set of GenRight LED side markers and mounted between the outer and inner fender with a right angle bracket from Lowe's, and just utilized the existing wire.
Attachment 455878
Attachment 455879
Attachment 455880
Attachment 455881Attachment 455882
~JDub
Attachment 455878
Attachment 455879
Attachment 455880
~JDub
Thanks... Nice jeep I can tell you like it (A LOT) because you attached quite a few pictures. Do you ever go outside and just take pictures of your jeep?
#475
#476
Finally got up the courage and am happy with the results. I did not want to use any edge trim, especially in the AZ heat where the adhesive would just get soft and make a sticky mess. I took my time to get smooth clean lines, and here are the results.<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=458866"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=458869"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=458870"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=458871"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=458872"/>
