Trimmed Fender thread post ur pics here!
Old 09-19-2011, 07:03 AM
  #271
chicky_regal's Avatar
Default I'm in...
Did it yesterday. Stock fenders are now trimmed. No pics to post as it was dark when I finished, but I'll get some up in the next couple days. I did not take the fenders off the jeep. I used a utility knife on the driver side (heated the fenders with a hair dryer, sliced like butter). Used snips to clear the support tabs from the underside. Used a cutting disk on a dremmel for the passenger side. Truthfully, I thought it was easier with the utility knife. The dremmel melts the fender and throws the hot shrapnel all over the place, including your arms, face, neck. I left the marker lights intact, but had to trim the tabs that hold them to the fender support with snips. I still need to put on the door panel trim to finish things up. I have not decided if I'll put the inner fender wells back or not. I might go ahead and hit the rear wells with bedliner. Thoughts?
Thanks, jim
Update 9/21...pics added today. I hit the edges of the fenders with some sandpaper and they look pretty good, so I will hold off on the door edge trim. I did end up trimming the front fender well plastic and putting it back. I also got two rattle cans of black bedliner from autozone and sprayed the rear fender wells last night. Job done.
ID:	213818Click image for larger version
ID:	213819Click image for larger version
ID:	213820Click image for larger version
Old 09-19-2011, 12:03 PM
  #272
tslewisz's Avatar
Sorry about the lighting...
Old 09-19-2011, 05:33 PM
  #273
jaker t5's Avatar
With my full width bumper
Old 09-24-2011, 07:43 PM
  #274
ben1284's Avatar
Originally Posted by NebRedrocker
I'm curiuos how those trimmed fenders have held up over time. Are they keeping their shape after a harsh winter with lots of snow and ice? For those down south in the heat, how are they holding up? Thanks for any input, I'm looking at taking my bb out and trimming the fenders.
Mine are just fine. Have had no issues since they've been cut.
Old 09-25-2011, 07:10 PM
  #275
CONQRRR's Avatar
well, everyone else is doing it so i might as well too
torn between cutting my sahara flares or buying the regular plastics and cutting those instead...
Old 09-25-2011, 07:13 PM
  #276
daspes's Avatar
Now how about from someone that gets some snow and ice. I'm getting real close to doing this if they will keep their shape after some varying weather.
Mine survived the weather of the PNW, an entire winter in NW PA next to the lake and the moderate weather of VA just fine. As long as you leave in the inner support they will be just as strong as they were before you cut them.
Old 09-25-2011, 07:27 PM
  #277
CONQRRR's Avatar
Chop some cheapies first, I saw a set on CL a while back for $50 for all 4 flares.
cheapies would mean chopping my sahara ones so i don't spend money since i just spent a bunch on jeep stuff the last 2 weeks. that being said, i'm meeting someone on tuesday for their plastic flares for 60 bucks. i know not how to stop spending!
Old 09-25-2011, 08:34 PM
  #278
Guitarnstuff's Avatar
Does doing this chop allow you to run 35's without a lift on a 4 door JK?
Old 09-25-2011, 08:42 PM
  #279
o09jkny's Avatar
Originally Posted by Olean NY Jeeper
Here is my super conservative fender chop. Just took 1 inch off the front of the fender from the light to the grill. Came out nice. Used a coping saw and took my time.
Before:
After:
Kind of amazing that one inch can make that much difference visually.
Nice job.. Did you use a KABAR? Olean, N.Y., get it?
Old 09-26-2011, 02:22 AM
  #280
westchester's Avatar
NY state daily driver here, and they're the same as when I chopped the fenders a few years ago. Weather has no effect.
Quick Reply: Trimmed Fender thread post ur pics here!
