Trimmed Fender thread post ur pics here!
Old 03-06-2010, 03:11 PM
  #181
DjCO2's Avatar
Hey guys, I just cut my fenders and added the door trim but found that my cuts weren't very straight... The door trim shows minor "curvyness" throughout the cut and this is something that I haven't seen on any of your chops. All of your cuts look very straight edged. Anybody else run into this? Any ideas how to fix It's really bugging me. I used a handheld saw powered by my compressor. The blade is the flexible type.. Thanks
Old 03-06-2010, 03:13 PM
  #182
BBirish's Avatar
after you make the cuts sand them down
Old 03-06-2010, 03:20 PM
  #183
DjCO2's Avatar
What type of sand paper (grade, block, wet, dry) should I use? Thanks
Old 03-06-2010, 03:45 PM
  #184
adamisadam's Avatar
get a variety pack at an auto parts store. I'd assume you'll want something HD like 80 grit and up. Use a block to get it smooth. A long block would be better I guess. And dry, not wet.
This is all based on knowledge but I haven't experienced trimming mine yet.
Old 03-06-2010, 03:53 PM
  #185
nukeman's Avatar
Get a foam (80 grit) sanding block from Lowe's/Home Depot. Works like a charm for sanding down the "imperfections".
  #186
DjCO2's Avatar
Cool thanks guys. I'll get some pics up sooner than later I hope..
Old 03-06-2010, 05:37 PM
  #187
jcole's Avatar
Cut mine with a dremel. Took 2 discs total. Used a razor knife to clean off the burrs in the plastic after. Just gotta go to the store and get some door trim stuff.
I basically just trimmed away the vertical part of the fender, and tapered it at the bottom to prevent damage from the rocks.
Old 03-07-2010, 03:50 AM
  #188
westchester's Avatar
If you use a grinder with a cut-off wheel, you can slice off any small areas, pretty easy to make the entire length smooth and consistent. I agree with using sandpaper for final step but I think a grinder is the best tool for as you describe. A cheap grinder is about $30.
Old 03-07-2010, 05:15 PM
  #189
DjCO2's Avatar
Yea I think I'm gonna have to buy a grinder because I took off the door trim and it left a sh1t load of adhesive that can be removed with goo gone and patience... but I think the hardware store was sold out of the second thing because I just couldn't find any anywhere .
Well, here she is...
I gotta say, she looks a lot more like a JEEP now.
Old 03-07-2010, 06:38 PM
  #190
TheonlyREDhead 2008 JK's Avatar
Very nice!!!
Quick Reply: Trimmed Fender thread post ur pics here!
