Trimmed Fender thread post ur pics here!
#151
#155
#158
Tape up your lines with blue or white painters tape and leave it for a couple of days relooking and retaping until happy with all, then break out the fun tools. I used a cut-off wheel on a grinder which slices easily (dremel wasn't powerful enough IMO) and a hand hacksaw for the corner parts near the body.
I'd suggest cutting and removing in small sections (esp the box section around the sidelight) and cut the excess away first and then cut on the exact desired line later.
If you're keeping the inners, chop them very gradually and AFTER the outers. I chopped too much inner on first fender.
A cheap heat gun will melt the door edging glue (superglue it if doesn't stick) and melt the corners for a finished look. I bought 25-foot and used almost all.
Not much else to tell. Check out WOL's write-up also.
