Torque issue
I replaced the bolt, I could not find a grade 8 that was the same length, was a little bit too long. So the bolt I found, I spaced the head with a couple of washers, should this be fine, will I have any issues retaining the torque on this bolt?
What ended up being wrong with the original bolt? You might have a problem with the nut, too.
OEM Parts:
Bolt, 06104265AA, $8.35
Nut & Retainer, 06508598AA, $2.35
These are pretty important pieces. Maybe even corrosion resistant coating on them. I suspect the bolt strength is greater than grade 8, but, I don't know for sure. Not knowing would make me want to get the OEM bolt and nut.
OEM Parts:
Nothing appeared to be wrong with it, damn thing just wouldnt torque. My guess is it had too much "spring" in it and was probably about to pop. Factory probably overtorqued it or something and ruined the bolt
OEM Parts:
OEM Parts:
I personally think your better off with a standard grade 8. I ordered a brand new OEM trk bar bolt for my wifes TJ, Broke the original off trying to torque the bolt. Had to put in a grade 8 to get by with until the new one came in. The new one came in along with a new flag nut. Torque on the TJ is lower. The OEM would not torque to 55ftlbs, it snapped. Put the grade 8 back in , no probs. I also noticed when trying to check torque on my jk rear control arms, it seemed like they were fixing to snap. Wouldn't torque to 125. I replaced both lowers with grade 8's, torqued, no prob. I don't think all these OEM bolts have the same quality as standard grade 8's. Just my opinion.
It seems the evidence is stacked against the OEM hardware.
Thanks for making me do some homework.
Check this site h**p://www.americanfastener.com/technical/grade_markings_steel.asp
Is the grade 8 bolt the same diameter as the OEM metric bolt?
Is the length of un-threaded portion of the two bolts the same?
