tires wider than 12.5"
ok. first i forgot specs, then forgot pic...im lost today...here they are together.
20in Ultra Magnus in Matte Black
BFG KM2s (325/60/R20)
thats roughly 13.5 inches wide, and 36 inches tall
I know its not a whole lot wider than 12.5, but I hope it helps.
Toyo MTs come in a 35x13.50/15. There's a TJ at work with them that looks pretty good. There's definitely something to be said for the grip of a wide tire. But they are harder on steering gear. I've worn out a Tri-County Gear's HD tie rod. Make sure you keep enough offset on your rims so your tire pivots instead of scrubbing during a turn. Also, the wider the tire, the more they'll grad on drainage grooves at highway speeds.
By the way, I notice that YJ has an IF front suspension. I don't think he could do a u-turn in a football field.
the white JK is ricksterjeep and he runs 15" wide 35" Mickey Thompson MTZ.
these things are meaty!!! sorry i dont have anything closer... maybe he does.... i'll pm him and have him post up some close ups.
correction... the correct tire size is 36x15.50x18 he said he'll take and post some close ups soon
We wanna see...
