tinted lights..NITE SHADES..PICS
Old 10-10-2007, 04:17 PM
  #21
blk07jk's Avatar
I'm going for a blacked out look this is perfect.Thanks
Old 10-10-2007, 04:44 PM
  #22
GATECH's Avatar
Looks good. Nice setup!
Old 10-10-2007, 06:14 PM
  #23
BARNO's Avatar
MORE PICS ANYONE????
Old 10-10-2007, 06:18 PM
  #24
JK-RUBIJON's Avatar
I will see if I can get some pics of mine tomorrow if my camera works.
Old 10-10-2007, 07:20 PM
  #25
JKDAVE's Avatar
wow thats so awesome on my other truck i used tints but it was a film that went over the tail lights, that looks way better...
Old 10-11-2007, 06:00 AM
  #26
redWRANGLER's Avatar
Jeepik,
Did you sand your lenses before you applied the nite spray?
Old 10-11-2007, 07:17 AM
  #27
JK-RUBIJON's Avatar
I scuffed up mine with sand paper. you can use 800-1000 grit and that will be fine once all the gloss is gone take some alcohol and rub it down to clean away any oils left from your fingers. Than spray away. I would suggest that you put a clear coat on afterwards to help keep the tint there.
Old 10-11-2007, 07:21 AM
  #28
JK-RUBIJON's Avatar
One more thing there is two different types of spray. One is like water and the other will come out more like paint when being applied. I have uesd both in the past. the paint like one is much easier to use. the water like spray was hard to get to look right . It took multiple times of doing it and sanding it back down to get the lights to look good. This was on a different car. The paint like spray worked way better for me this time around.
Old 10-11-2007, 07:30 AM
  #29
Do you have a recommendation on the brand that sells the paint-like spray?
Old 10-11-2007, 08:33 AM
  #30
JK-RUBIJON's Avatar
It is actually the same brand so I am not sure why the two different types. there are a few different brands on Ebay that You may check, but I got mine from summit racing and would recommend going through them. part number VHT-SP999 good luck.
Quick Reply: tinted lights..NITE SHADES..PICS
