tinted lights..NITE SHADES..PICS
Old 10-29-2010, 02:48 PM
  #131
DDloadedJK's Avatar
Yo. If your doing the turns and side markers, go only 2 coats of nite shade on the markers, otherwise way too dark. IMO. 3 coats on turns and tails
Old 03-07-2011, 02:49 AM
  #132
i just got a ticket for my tinted taillights
also got 1 for my window tint
not sure if i can get out of the tailight 1 or not, but i can get out of the window tint
Old 03-07-2011, 04:03 AM
  #133
mr.brav90's Avatar
im going to do this when i go home for spring break... is how many coats have you found out works best and any tips or tricks to doing the tail lights?
Old 03-07-2011, 04:55 AM
  #134
mldsrt4's Avatar
i did one thick coat on mine and they came out great...i did my front markers, corner markers tail lights and 3rd break light....make sure you scuff up all your lenses before painting..you dont want scratches just want the plastic to look hazey then clean with rubbing alchahol and paint...this stuff will not look dark when you are painting...but trust me when it dries youl realize its dark enough, so better not enough then way too much....here is mass im sure they are illeagle but police dont pull you over for it, more somthing they mention when they pull you over for other reasons. had it done on my pearlwhite srt4 really dark and not once did i get pulled over for it....my pics of my work suck but here ya go
ID:	134621   Click image for larger version
Old 03-07-2011, 05:08 AM
  #135
mr.brav90's Avatar
ice looks good thanks. did you take off the third break light to do it? and does it just pop right off, cant say i have ever really studied it before
Old 03-07-2011, 05:47 AM
  #136
IcyFridge's Avatar
The hellas have the lenses painted, not the external glass. That is completely different.
What I did was I sanded my lens down and 3 light coats of VHT with 5 mins in between. 10 minutes after final coat of VHT and I put a light coat of clear acrylic enamel. 3 more coats of clear with 5 mins in between.
My lights are darkened but glossy and shiny. Looks professionally done. My reflectors still shine through them and I passed state inspections with them as well.
Problem is: most people don't take their time for multiple coats or prep time. The clear also helps a LOT.
I will take a picture of my lights soon (nearly one year later since painting them and very slight fading. Fading has stopped and the lights are a perfect hue/saturation now.)
Old 03-13-2011, 05:03 PM
  #137
dcirate25's Avatar
Finally did mine!! Came out good. Went a different route tho. i just taped around the front lights instead of removing them. Only took about an hour. 2 coats of rustoleum lens tint and 2 coats of clear. Very please with results. Windows are getting tinted on wednesday then the jeep with almost be murdered out!
ID:	137293   Click image for larger version
ID:	137294   Click image for larger version
ID:	137295   Click image for larger version
ID:	137296   Click image for larger version
Old 03-13-2011, 06:06 PM
  #138
Feasterdef's Avatar
Wow. U did it with lights on truck. Yikes!
Old 05-15-2011, 02:54 PM
  #139
yrubuggin's Avatar
Same here. This is how I taped it before paper went on. Was pretty easy to just tuck the tape in, since the fender pulls away from the marker.
Old 09-12-2011, 11:05 PM
  #140
Dynamo's Avatar
I say use your common sense. Tint the lights a bit but don't go too dark.
Quick Reply: tinted lights..NITE SHADES..PICS
