Thoughts on smittybilt rear bumper 76855
I was wondering what people's thoughts were on this bumper, I found one on kijiji from a guy for 300$ but is that to much? There is no tire carrier with it.
Former Member
1 Post
Not a bad deal....the tire carrier was the issue some of them had it wiggled and wore loose where it clamped...so no tire carrier no issue...its a good bumper they are all pretty much the same for $300 I say if you like it go for it....
So I had to cut the hidden hitch off, back plate off my frame is bent from the previous owner where the hitch goes and I couldn't get that piece back straight, even with a 3/4 ton cumalong and heat on it it would t bend back straight. So I had to cut the plate off the back to get it to fit, will have to re weld that piece after, but so far I like the look.
