Thanks MBRP
#31
Can someone with experience with both the relocate kit and the standard catback tell me if there is a difference in "cabin" noise levels between the two. I like the idea of the relocate kit, but I don't want anything louder inside than it has to be and I'd think the standard catback would be quieter given that the muffler is at the back of the vehicle. I don't want to spend a bunch of money on it and crush it but I'll take my chances if there's going to be a significant difference in the noise levels.
I've had a couple of vehicles that had much louder exhausts than I expected and I'm trying to do my research and avoid doing this again. Especially, since my fiance hated the exhaust on the XJ I had when we started dating and if its too loud she'll start paying more attention to the mods I do to my JK and the money I've been spending on it. So far she's been looking the other way.
But..it is much louder then stock. Other mufflers are even louder though.
OK, gergi9... You can drive without the last two pieces. That piece just gives it a twist point to get the rest of the tailpipe lined up and only goes from the muffler to the final tailpipe (the part that has the bend for up-and-over the rear axle. Make sure you twist everything and get the pipes all lined up and check for interference, and that the hangers are ummm hooked.
#32
Well i am not going to try and drive it without the last 2 pieces because nothing would be holding on the muffler except for the front clamp.
I just talked to Steve @ MBRP and they are getting the right part out to me today. Hopefully it gets here quick and i can have my baby back.
#33
Sponsoring Manufacturer
MBRP Representative
MBRP Representative
Steve
#34
Thanks steve. It was home waiting for me!. I do one more question. I can't seem to get both the over-axle pipe into the hanger and exit pipe into the hanger at the same time. It only seems to fit one or the other into a hanger. Is their a trick to this?
thanks
thanks
#35
I installed the relocated system today. It took all of 9 minutes. Getting the stock exhaust out was not as quick, though.
I had my local shop order me one yesterday and it came in today.
I love the new sound.
#36
Good luck.
#37
I installed mine yesterday. I too had just slipped that hanger in and did not like that. I tried again and got it all the way into the hanger which raised the pipe higher. I believe that is the way it should be. The rubber hanger should fit in the center of the curve in the rod.
#38
MBRP Representative
MBRP Representative
Hopefully that made sense.
Steve
#39
MBRP Representative
MBRP Representative
#40
just finished (i think) installing my 2 dr relocation kit. as people have mentioned here and in other posts - removal of the stock system is a bitch - but everything else seemed to work pretty good and i am very pleased with it overall. i have a couple questions for mbrp and am going to call them in the morning, but wanted to see if i could get some answers here from other that have installed the system.
is the e-brak cable supposed to go on top of and the the driver side of the pipe, or below and towards the passenger side of the pipe? it seemed to be a toss up on which way to route it when i was lining up the pipes before tightening down, so i picked one (below and to the passenger side of the pipe). after i tightened everything down i took it for a test drive and after about a couple miles of diving i got out to check it and the pipes had "settled" and were now in contact with the cable. i've moved the cable again, but i'm pretty much out of room and it's still close to the pipe. anyone else have this issue? the instructions state to check if any wires cables need to be relocated, so i'm not suggesting it's a defect, just wondering what others have done.
also, mine seems to have quite a bit of play back wear it goes over the axle. do others have this? i'm just wondering if i have installed it properly. doesn't seem to have a stable fit for me. and honestly, the end dump seems a little crooked - so again, wondering if i've installed it properly. i played around with the line-up before i tightened it down, but where i had it seemed to be about the best positioning. i'll try to get some pictures, but was wondering if others had ideas.
