TeraFlex Tech: HD Hinged Carrier and Adjustable Spare Tire Mount
#32
Rebel Offroad just posted this sneak peak pic of TF's long awaited Hi-lift/rotopax mount for the carrier....
Attachment 394070
Attachment 394070
#33
Originally Posted by Vin
I hope there is a way to mount a Rotopax without the Hi-Lift jack.
Thanks for sharing the pic k0260!
#34
Attachment 394070
Attachment 394070
#35
#36
That looks like a ton of rattling to me. Also very easy to steal. I wish it was just a rotopax. We need to find out what bolt size the hole is and get a universal rotopax mount
#37
Sent from my DROID RAZR MAXX using Tapatalk 2
#38
What tips/tricks are there, to get the studs into the tire mounting bracket?
Tried the lugnut/spacer trick.....
It go them started, but wouldn't pull them through.
It stripped the threads on the lugnuts (tried two) instead.
Will a regular Big-O be able to press them in?
#39
I ended up using a piece of wood to get it off the ground, then put a big deep socket around the threaded side to give it support and room to move into the carrier and then used a BFH to pound them in. Worked like a charm. Hope that makes sense.
#40
After stripping two lug nuts and wrestling with the thing for an hour,
I sure enough had the gumption to beat something.
However the TF instal vid advises against the hammer technique.
Any other options. Local Desert Rat shop said I need to schedule it for after Xmas.
I dont think so.
HAMMER TIME is sounding pretty darn good
