Teraflex Leveling Pics
Here's a shot of after the Tereflex kit was installed on stock wheels and tires. Don't know if this helps you or not. Does add some lift (about 2 1/4" front, 1 1/4" back from my tape measure) and sure gets rid of the rake (the reason I got it).
[IMG][/IMG]
The 33's are coming, just have to scuff off the original tires a little more. Sucks living close to work - tires last forever!
[IMG][/IMG]
TF leveling kit with Goodyear Mtr's with kevlar in 275/70/18..33's
I only had a slight rub on the front sway bar at full lock...I adjusted the steering stops with a couple washers on each side..I was good to go at that point..I did some wheeling right after the new tires and no rubbing and those Goodyears are awsume...
Okay, I apologize if this is a stupid and obvious question, but could I buy the Teraflex Leveling Kit but also purchase OME shocks to replace the stock X ones?? Can I even do that? Or should i just go ahead and purchase an OME lift kit altogether?? I'm trying to keep the cost down to a minimum and I know that the Leveling kit is only $120. Plus the shocks aren't too expensive either.
I plan on getting 33's because the JK is my DD. With everything that I should buy for the OME HD lift, its going to be way too expensive for me. The Leveling Kit kinda fits my needs the best and my budget
Thanks
Thanks
