TeraFlex Jeep JK Products Overview video
Sponsoring Manufacturer
Driveshafts: TeraFlex driveshafts come with new yokes for both ends. You can run the stockers untill they fail.
It appears the tie rod in your well produced video is also flipped to the top. Is that an item Teraflex offers for the factory d44, or is it only applicable with your 60 axle?
That tie rod setup is only for D60's or with the TJ High Steering kit. TeraFlex stills needs to get a JK specific tie rod to market.
I had the Draglink Flip Kit installed along with my 4" short arm kit. Mostly for the geometry fix but I also noticed significantly less body roll in a turn than stock. I'm still running the factory swaybars front (Rubicon e-disco) and rear and have no plans on changing them unless they break.
Whose ever idea it was to start making these videos is pure genius. I always wondered about quality control when it comes to spend over $200 on any product and you guys at Teraflex obviously believe in your products which brings peace of mind to me. The more you guys make these videos the more I want to spend but man its well worth it! Keep it up guys
high quality production.
the JK frame with the suspension setups is perfect. good job.
based on the fact you've made pretty much all the other parts, when can we expect a TF Monster Tie Rod or TF skid setup?
Yes, but we are waiting for the end caps to come in.
Skids, mostly likely never. Tie Rod?
Thank You! I will pass this on to the owner.
