Teraflex 2.5" coil lift installed!
#21
The lift feels great on the road. I think I can get a really good comparison too as I am still running the same stock tires. I think some of the differences people feel and blame on the lift are a result of larger tires and heavier wheels.
#24
I cant wait either! Hopefully the wheels really do come in at the end of the month as I can not wheel offroad with the stock wheels without spacers. I will probably call in a few days and try and get an estimate. I too am very impressed with what these Jeeps are capable of stock.
#26
From what I understand you are correct and the tires will rub the links at significant flex offroad. I would rather not test this and find out. I have already tagged the sidewall of the tires on the front when they contacted the disconnected swaybar before I got the lift. I now just remove them completely. This should not be a problem with the new wheels as they are 4.25" BS and I also adjusted the steering stops. However, this is not an issue for daily onroad driving as long as you install the rear sway bar links on the inside of the bracket like the instructions say.
