Strengthening stock drag link end
#25
I may be giving these a try, steering is getting sloppy and have some bump steer, checked everything and the ball joints are good. figure I was gonna upgrade at some point anyway so better sooner than later.
#26
Originally Posted by PainKiller
the currie drag link looks like it comes with heavy duty ends. well the one at Northridge is pictured with them already attached
#27
is the moog end just in case you damage the oem drag link end when pulling the pitman? im wanting to pull my drop pitman and put stock back on today while my dad is here to help and just curious.
#28
Part that is greasable that will last
a lot longer. I had death wobble issues and this helped cure it. If your stock end is not damaged you don't have to replace it, but for $22 it can't be beat and couple with peace of mind.
#29
I noticed that although my drag link and tie rod ends are fine, as far as wear, they still move around quite a bit, and clunk when going over a speed bump or some such thing. I can see the Moog drag link end at the pitman arm being a very good replacement that might alleviate some of this clunking...but are there replacement outer drag link & tie rod ends for the OEM tie rod that are similar to this drag link end? Thanks
#30
stock Tie rod Moog part ES800593 right
ES800594 left
Drag link ES3624
