Strengthening stock drag link end
The Moog ES3624 Tie rod end was designed for Dodge Ram 3500's. It fits the JK OEM drag link to the pitman arm and Rock Krawler tie rods. They are Greasable and heavy duty(no plastic interior parts like OEM) and sell for around $22. I just put it on, including the Currie Tie Rod. Both are pure grade A Beef.
Also did you grease it yet? I am trying to figure out where the grease comes out on the Currie tie rod..
Thanks for the pics, but what I mean is when the boots are on, where does the old grease push out when you grease it? Where does the old grease escape?
U don't want to see any grease come out according to currie. There not greased like a typical joint where u want the boot to fill up.
Two to three pumps every oil change. That's it.
If u did over grease it would come out the sides or the center of the boot.
So where does the old grease go? If you grease em every oil change, they will fill eventually..
