Side-mount Jerry Can Carriers for the JK
#61
I know on Ebay every now and then a used Scepter gas container will show up but the prices they're asking for them now is outrageous. I remember picking up brand new ones for like $40.
Maybe you can try one of their Water containers instead? Those usually run much cheaper.
I've got both. There's not much difference outside of the cap. But I'll double check to see if the handle gaps start around the same height....
Doesn't really matter though if the handle gaps are at the same height, with this strap design you can just add or remove links in the chain to make the strap the right length. In the photo I posted showing the two ways to use the strap with the jerry can, putting the strap over the cap took one more link than putting the strap under the handle. Based on the adjustability and the flexibility provided by the links, I'm confident this strap will work well with Sceptre containers. But I'll try to pick one up for testing just to be sure.
#62
Today I finished up the universal adjustable/locking gas can straps I started making a week or so ago.
I'm really happy with how the straps work; the removable chain links provide a lot of adjustment, and the latch provides fine adjustment to snug the cans down tight to prevent any movement or rattling. They adjust fine for jerry and NATO cans as shown in the photo; for the jerry can I looped the strap around the cap to prevent that from being opened. Also in the photo above, I've used a short piece of Velcro One-Wrap around the lock, which prevents it from rattling as well. The jerry can took one more link in the chain than did the NATO can.
Here's a closer look at them; there's a waterproof PVC-coated polyester canvas sleeve that goes over the chain part which prevents the chain from scratching the can and provides a degree of weather protection for the chain. To make it easy to add or remove links, I put a zipper in the sleeve so it's easy to zip on or off for access to the links. The hooks at each end of the strap swivel so the strap and be used at an angle like with the jerry can above or vertically like with the NATO can.
I'll use these whenever I feel I need extra security for the cans, other times I'll use the ratchet straps that come with the can carriers, they work great too.
#64
If these get picked up for sale by an official forum vendor, I'll let people know. If they end up being sold by outlets that aren't forum vendors, according to forum rules I won't be able to post that.
#66
Speaking of that, here's an idea I've been toying with... brackets to mount a jerry can on the HD tailgate hinges. I haven't made them in metal yet, but here are some cardstock mockups of the brackets.
The brackets would hold the same can tray I used on the side mount earlier in this thread and they're reversible, so they'd either mount in a low position or a high position as shown in these concept drawings:
In the low position, in most cases the can would prevent the tailgate from opening all the way because it would hit the tail light, so it would have to stop at 90 degrees instead of opening to the factory 110 degrees. It wouldn't be too hard to make some add-on stops for the HD hinges that would limit their opening range to 90 degrees so the low mounting position could be used. Or the same brackets could be flipped over to mount the can in the high position, which would allow full tailgate travel.
I'm still experimenting with these ideas, I don't know if they'll end up being practical or if I'll end up making up a set in metal to test on the Jeep.
#67
I was just wondering if the side mounts are out yet and if you can tell me were i should be looking. I have been searching all over the internet if you can please pm me this will be perfect for the build i am doing.
Thank you
Thank you
#68
