Shrockworks Rear Tire Carrier
Old 11-22-2008, 07:20 PM
Gokracer1's Avatar
Looks great! Shrockworks does make some good stuff
Old 11-22-2008, 07:28 PM
Strong Bad's Avatar
Very nice!!! I also like the front bumper!!!
Old 11-23-2008, 02:49 AM
pearl-drum-man's Avatar
Looks awesome!
Old 11-23-2008, 04:37 AM
Former Vendor
tgrt's Avatar
Originally Posted by doc307
That's exactly what I did Tony. I think I am going to go back and raise the carrier 1 hole though.
Why's that if you don't mind me asking? The visibility and center of gravity look to be improved quite a bit -- at least from my previous setup.
Old 11-23-2008, 06:11 AM
doc307's Avatar
I don't like the way the bump stop works like that. It's hard to get it level.
The visibility is not an issue since my sons car seat blocks more of my view than the tire will.
I will have to think about the center of gravity though.
Old 11-23-2008, 06:54 AM
JK-ing's Avatar
Very clean. Now go get some lights to fill those holes.
Old 11-23-2008, 07:04 AM
doc307's Avatar
The lights are actually on the way.
Old 11-23-2008, 10:55 AM
Former Vendor
tgrt's Avatar
Did you put the bolts on from the bump stop as explained in the little instruction sheet that came with the bump stop? If not that might be the problem. Mine sits perfectly flat although it's not fully on the plate. I just couldn't use the washer in the inside, because there was no room. It shouldn't matter though.
Old 11-23-2008, 04:44 PM
doc307's Avatar
I think I put them on per the instructions.
Old 11-24-2008, 07:30 AM
you can use two nuts on the outside and then the washer fits flush, thats how my bumpstop is sitting
seems to be working fine
Quick Reply: Shrockworks Rear Tire Carrier
