Shrockworks Mid Width & Winch
Old 12-18-2007, 08:54 AM
  #31
rusty jeep's Avatar
Nick,
My mistake....I have slept several weeks and forgot that I can't get the driver side front bolt in for the winch not the back one. The bolt is not long enough.
I have looked at several hardware stores and can not find the length in a grade 8. I have M10x34 that came with the winch. I have found longer bolts but not grade 8. Will these work. Do you have a longer grade 8 that I could buy from you.
Thanks,
Rusty
PS I love my bumper... It looks great!
Old 12-18-2007, 04:15 PM
  #32
rusty jeep's Avatar
This is my shrockworks mid.
[IMG][/IMG]
Old 12-18-2007, 04:22 PM
  #33
mcnaught6's Avatar
Originally Posted by rusty jeep
Nick,
Thanks,
Rusty
maybe you accidentally used one of the longer ones in the rear, or used them to fasten the skid plate.
i remember that there were two bolts that were longer to be used in the front position to secure the winch. you can use the bolts that came with your winch for the rear legs of it, but you have to use the two longer ones that shrockworks gives you for the front two legs (instead of using the bolts that came with the winch).
i would check to see if one of the bolts you used on the skid plate are longer than the others. if it is, then that is the one that you should use for the winch.
Old 12-19-2007, 04:50 AM
  #34
Former Vendor
ToyFamily's Avatar
The bolts we send that are longer are SAE as the majority of the winch companies have SAE nuts incl. , so if his winch has Metric nuts it won't matter. We'll get it taken care of.
Nick
Old 12-19-2007, 06:29 AM
  #35
SLICKWILL's Avatar
looks great
Quick Reply: Shrockworks Mid Width & Winch
