Show your Tuffy Security Full Console!
#41
The LED is from STREET GLO. Below are two links that solved a problem all our JK's have. I plan on using these LED's on many more projects I have planed.
https://www.jk-forum.com/forums/show...ght=street+glo
Find the orange wire w/ white stripe and splice into it. This is the instrument cluster light circuit. It works great.
The transfer case knob pulled off. I just grabbed a hold of it and pulled straight up. Came right off!! The Auto Trans portion is untouched. The full install was really easy.
#42
I just installed mine today. It's great, except the transfer case shifter doesn't center up exactly in the slot for it. I tried to shim it and attempted to bend it. Still no good. Any one else have this problem?
This is a quote from the installation instructions note the second sentence. Very true, very true.
11. Place the 4wd transfer case shifter in neutral and remove the shifter knob. Remove the knob by pulling it straight off with
moderate force. It is not screwed on, do not try to twist and be careful what is behind you because when it comes off you may fly
backwards.
backwards.
#43
backwards.
![](https://www.jk-forum.com/picture.php?albumid=1473&pictureid=10343)
backwards.
![ROTFLMAO-2](https://www.jk-forum.com/forums/images/smilies/cheesy.gif)
![Taunt](https://www.jk-forum.com/forums/images/smilies/taunt.gif)
![ROFL](https://www.jk-forum.com/forums/images/smilies/rofl.gif)
#46
#48
